family KJ
JPOTM WINNER
I just took off the rear diff cover and there is no magnet in there...anywhere. It is my assumption whoever did the previous fluid change(before I owned it) lost it....and is it necessary?
Thanks all....I cleaned out the entire diff real good, even used my 1000w work light still did not see anything. I will go to napa. Can I just place it anywhere in the diff through the fill hole as I had to close her up to keep the day moving.
Are you sure you looked really good? Then Mag on a 8.25 is right below the carrier and is very thin...
Can't you just mount a big magnet on the ouside of the diff? It would still "attract" all those metal shavings until you change the fluid again.
Bruce
The magnet is on the bottom of the diff, it's got some grooves in it, mine looked like it was cast into the diff, I rubbed it when the mechanic had the cover off, and it didn't seem like it would move. I was very small about one inch square.
