Rear lower control arms
RenKJ
Canada
Prices in CAD$
MOPAR 52088682AB $50
MOOG CK641180 $65
DORMAN 521982 $75
MEVOTECH CMS25157 $90
MOOG RK641180 $100
So I'm looking at control arms due to a slight drift when i gas it vs letting off the gas. I'm kind of thrown off by the mopars being the cheapest. Some have a rather different design. I want whatever is strongest /serviceable as ill be doing a lot more wheeling this upcoming summer.
There is a free replacement/ recall on them from Chrysler Canada.
Go to Link: Safety Recall Information | MOPAR
& type in VIN #.
The strongest I think are these that came with my 04 KJ.
54263[/ATTACH]"]
Spicer bushings were acquired,
54265[/ATTACH]"]
and where the axle side bushings had rubber cut-aways or slots carved in them, I filled in the slots with windshield urethane to take the slop out & make em stronger.
Allowed the Urethane to cure 2 days before having a 4x4 shop remove the old ones & use a 30 ton press.
They had to literally burn off the old bushings to safely press/ get em out!
ouroboros
Montrose, MI
I bought Mopar lower arms for mine... I wouldn't bother with pressing out the bushings, for the little bit extra ya get all new steel IMO.
4x4kayak2112
tx
I have a set of Mopars in the shop. Offroaded once, less than a month of daily use.
Then went to clayton arms. Much better.
Sent from my SM-N900P using Tapatalk
ouroboros
Montrose, MI
Which did you go with? I've heard of the TJ arms being used before but don't know which ones.
4x4kayak2112
tx
They are long arms. So new body brackets too.
Yes TJ or WJ adjustable arms will work, but make sure of the lenght before you order.
ouroboros
Montrose, MI
Ah yes, figured some cutting/welding might be involved. Would be interesting to have a direct bolt up kit. :emotions34:
4x4kayak2112
tx
Your not gonna have a bolt on kit for the KJ without some cutting atleast. The brackets could be bolted on.
TheBlueKJ
South Jersey
Couldn't you use WJ adjustable rear lowers won't they just bolt right up?
Sent from my iPhone using the power of children's laughter
4x4kayak2112
tx
You could if the lenght is right.
RenKJ
Canada
How did that work? Did you cut off the old brackets and drill new holes? Was it the WJ arms that you used?
Are claytons overkill? They seem pricey
4x4kayak2112
tx
No they are long front lower arms from clayton
Yes you have to cut off the body mounts . I make the mounts that weld to the frame rail.
Overkill? Have you seen my KJs and everything I build for them? But expensive......try and build them yourself, you will come $60 to their price
RenKJ
Canada
I meant overkill for myself [emoji14], if it involves welding I might consider waiting till spring to do new lower arms, dunno if i wanna shell out 400+ though for the arms, I'm in Canada as far as pricing.
Was hoping to find out if any of the oem replacement arms are grease-able or serviceable
None of the OEM or anything made for the KJ is greaseable. Aftermarket ones yes of course
Just a different view, I have had to replace mine once in over 218,000 miles, Thankfully it was the same time they came out with the recall :icon_lol:
RenKJ
Canada
Hmm I'm gonna check if i still didn't get control arm recall and if not will probably just go mopar then, i have a feeling i won't have recall cause ive already gone in for trailer hitch and they never mentioned it
Ps: did you fill yours with polyurethane in those vent looking holes in the rubber?
Did my original set
second set never did .
Wanted new ones on ASAP they were that bad , dealer sent me a pair , never even went into have them done
