Rear recovery point.
Which recovery point?
  • #1 Hollow hook
    Votes: 3 11.1%
  • #2 D ring
    Votes: 21 77.8%
  • #3 Solid hook
    Votes: 2 7.4%
  • #4 Solid ring
    Votes: 1 3.7%
  • Total voters
    27
  • Poll closed .
ptsb5a
Northern Alberta, Canada
You do know its not solid right?
Does it really matter? The bolts holding the hitch on or the reciever pin will fail before you rip the sides out of that reciever. Stuffs like 1/4" isn't it? When under a shear load, that steel will be plenty strong enough. And even then, it's the D-ring pin and the reciever pin that are in shear. Personally, I wouldn't worry about the reciever being hollow.
JeepINgeek
Silver Supporter
For Twain In Diana
exactly right.
whatever
I just like the solid ones way better for the money
plus if someones a jerk I can throw it at em!
In the last thirty plus years of wheeling I've seen enough cheap stuff break that some have said " don't worry about it, its strong enough"
Actually if using a 1/4" walled tube will have more "shear" force under the same load then a solid stock will since you only have a total 1/2" pressing on the pin where as the solid stock has 2" pushing on that pin.
This makes sense and I like the sound of "solid" better than "walled tube"....:smokin:
ptsb5a
True Troy, but in the end, it's the 5/8" pin that is in "shear", not the reciever tube or the hollow reciever. The force will be exerted on the pin itself. The tube will be in "tension"
Dave, in the Areospace industry, lots of things are made hollow, or have holes punched in them to make them stronger under the stresses that get applied.
