Rear sway bar
KingKJ
The Rock Spotter
Utah
Should I bother to keep my sway bar around in the rear once I lift my jeep? I've heard that you shouldn't run disconnects on the front(if this is wrong let me know), I've also heard that the rear swaybar isn't doing much, is it advisable to keep the rear swaybar or will it be fine without one?
u2slow
BC
I kept it. Felt the rear was pretty soft overall after lifting. Then I added load-assist shocks.
ikuo78
Japan
The rear sway bar has a strange structure.
The effect is limited because it is not connected to the vehicle body.
It appears to be controlling yaw rather than rolling.
In addition, it seems to take away the freedom of the LCA bush and reduce the load on the UCA pivot.
I keep it attached, but I'm sure many people remove it.
duderz7
Weiser, ID
I've been running without for years, it definitely leans more in the corners, but not much. I don't miss it and I definitely have better articulation without.
can't find the picture going the other direction, but you get the idea.
