Rear sway bar
KingKJ
The Rock Spotter
Utah
Should I bother to keep my sway bar around in the rear once I lift my jeep? I've heard that you shouldn't run disconnects on the front(if this is wrong let me know), I've also heard that the rear swaybar isn't doing much, is it advisable to keep the rear swaybar or will it be fine without one?
u2slow
BC
I kept it. Felt the rear was pretty soft overall after lifting. Then I added load-assist shocks.
ikuo78
Japan
The rear sway bar has a strange structure.
The effect is limited because it is not connected to the vehicle body.
It appears to be controlling yaw rather than rolling.
In addition, it seems to take away the freedom of the LCA bush and reduce the load on the UCA pivot.
I keep it attached, but I'm sure many people remove it.
duderz7
Weiser, ID
I've been running without for years, it definitely leans more in the corners, but not much. I don't miss it and I definitely have better articulation without.
can't find the picture going the other direction, but you get the idea.
KingKJ
The Rock Spotter
Utah
have you had any situations where it got a little hairy because you don't have the rear swaybar? That's really my only worry is that I take it out and then something dumb happens and I lose control.
Will your insurance cover you if you’re in an accident and the sway bar has been removed?
KingKJ
The Rock Spotter
Utah
I mean I'd assume so, probably would depend, that's why I'm making sure it doesn't make the car completely unstable
I would think that you would have to declare it the same as any other modifications done to the car.
duderz7
Weiser, ID
Nope, it's not a "fast and furious" car
When was the last time you saw an insurance agent get on their hands and knees to look under a vehicle in their khakis? If they were going to disqualify a claim due to modifications, it's obviously lifted.
If I gave the impression that it's unstable I misled you. I was in the same boat at one point, but figured I could remove it to try it out and put back on if I didn't like the way it drives. It's 4 bolts, takes 5 minutes. Obviously I never put it back on.
WWDiesel
Central Georgia
The sway bar does not interfere with the lift. The vehicle handles better in higher speed maneuvers with the sway bar in service.
I have about 3" of rear lift and have both upper and lower adjustable IronRock control arms and I left the sway bar in place.
