JeepINgeek
Silver Supporter
Does removing the rear sway make a difference? Does it help? why should i? why shouldn't i? whats you guy's and gal's opinions?
Almost 3 years without mine,never could tell the difference between having it on and off,have towed with it on and off,both 1500 miles through the mountains(at least 4000lbs each time) and no difference.The rear swaybar on a KJ is kinda worthless since it only ties the 2 LCA's together and that's it,it is not mounted to the unibody preventing any type of rear body roll like the front swaybar does.It does give you a little better flex(READ---NOT MORE JUST BETTER,easier) in the rear when offroad with it off.Does removing the rear sway make a difference? Does it help? why should i? why shouldn't i? whats you guy's and gal's opinions?
