and everything from Bob The Oil Guy is suppose to be right?
:shrug::happy175::icon_lol:
Of course not...there are lots of opinions there, just like in this thread. That's why I provided a link to hard numbers from an actual UOA.
Like someone said earlier, everyone has a choice for their own vehicle. I was simply providing something besides internet folk lore. If the syn was inferior, wouldn't the wear metals be high? If someone can provide some actual credible evidence, I'd love to see it. Syn lubes (including gear oils) have worked great for me in many vehicles over the years.
I wouldn't bother with paying someone to undercoat it. I'd just spend a day with a wire wheel on a drill, rusty metal primer and paint. A lot of the KJ's underbelly is galvanized.
My chief reasons for wanting to do the gear oil are these:
1) I don't know what they put in it when it was done in September of 2013.
2) With the extreme cold we have been having here the Jeep seems sluggish. The engine seems fine, so I'm think the gear boxes are meeting too much resistance.
3) I plan to do it way more often than needed and would like to be sure I know how. My theory on parts wear is that 90% of the wear happens on the last 20% of the life of the fluid. I plan to not get to that 20% usable life left point. It's kind of like in the gym, most injuries occur on either your first rep or at the end of a set when you are getting tired. I don't want any tired oil in my Jeep.
It'll probably be a week or two before I dive into the fluid changes. In the meantime, the PVC valves, etc., are fair game. I'm in VA right now and it's conceivable that we could see 50F degree weather by mid-March, which would make crawling around on the ground much more enjoyable.
I bought one of these at Harbor Freight last night to make the fluid changes a little easier. I'll let you know how it works. In the meantime, keep those suggestions coming. My successful water pump transplant two weeks ago has got me pumped to do more.
$7 worth of fun:
Multi-Use Transfer Pump
If you use 85/140 plan on the diffs feeling like they are full of oatmeal at negative temps. Once they warm up they are fine haha.
Cost $120 back home to undercoat,$$$ well spent.Granted it's law that every new vehicle sold must be undercoated before it leaves the lot.Truthfully, it keeps getting put off due to cost. When it was up on the lift at the dealer for the hitch recall last September everyone there (including myself) was amazed at how clean it looked. One mechanic remarked that there was no way it had been in NE Ohio for the past eight years. (He was correct, it was in VA Beach for the first six and a half years of its life.)
What paint is recommended? Can I do this without having it on a lift? I'd rather touch it up every year than wait until I can afford a pro job, at which point it may be too late anyway.
80w-90 will be just fine for you.Off-roading is just a dream for me right now. Towing will be infrequent for the near future unless I end up moving locally in the Cleveland area. Even then it would be one crummy week of shorter trips. Do you think I need the 85/140 under those conditions?
One of the most highly sought after diffs/3rd members for extreme crawling................UOAs on gear lube are kinda rare, but here's an example with a syn: Amsoil 75w90, 30K, 04 Chevy Tahoe | Gear & Transmission Used/Virgin Oil Analysis | Bob Is The Oil Guy
As you can see, the lab commented that wear metals were below average. Not sure where this internet myth started about syn gear oil being bad, but it's a myth that doesn't seem to want to die. I'd ask for some UOA proof from those perpetuating this old wive's tale.
The gearbox(or this case diff) temp is a good indication of proper heat transfer.What you can't measure is the bearing temps unless you pull the cover.If you think the gear oil is causing some sort of resistance you can check the temperature of the gearbox. Any "resistance" will show up as excessive heat or temperature. I use 75w-90 because I live in the snow belt and don't have anything to tow. 75w-90 will theoretically give slightly better gas mileage and run cooler compared to a thicker gear oil like 80w-140.
I thought I didn't have one because I have a manual transmission.....
Like others have said, for the transmission use whatever atf+4 is cheapest but be aware that the 07 has no transmission dipstick. You'll have to buy one separate and fill to a preset level based on fluid temperature. I plan on doing a simple drain and fill every 60k.
I just use rustoleum stuff. Spray is fine, brush on is for the ********. :happy175:My undercarriage looks near perfect and I haven't painted it for a few years.
Ahhh HJ, you can't fool me. You may not have PAINTED it in a few years, but you wash it EVERY DAY!!! :happy175::happy175::happy175:
:waytogo:
For the record I also use Rustoleum Hammer Black for the undercarriage. And like Tom I'll do a complete wire brush and cleanup this Spring so will probably use a full can.
