Got the front end done. It was really weird. The fluid that came out was bright red and when I went to replace it I couldn't get any more in. Then I got a transmission code pop up and the Jeep wouldn't move. I went in to have a sandwich while I thought things over. It was baloney, just like I'm feeding you.
(Hey, nobody is going to fall for an April Fool eleven days from now, so I thought I'd get one in early.) :happy175:
No leaks! The old oil didn't look horrible but it was pretty black. Found a very straight stretch of road and kicked in the 4WD to see what happened. Nothing unusual, so I guess it worked. I wish there was a sensor or something to reassure me, though. Someday I'm going to get a good temperature probe, then drive around and see if it seems super hot, though I don't know what the definition of "super hot" would be.
I'm embarrassed to admit it, but I tried to save a few bucks at Harbor Freight and bought the 3-Ton jack stands. As soon as I took them out of the box I realized they weren't going to do it and went back and exchanged them for the 6-Ton set, which is about 7" higher. (~16" vs 23") This put me about an hour behind schedule. I was afraid it would get dark on me if I ran into trouble so I'm planning on doing the back end tomorrow if it's not too cold. I have had a bad cold for three full weeks now and still need to pace myself.
One final note: It took about six ounces more oil than I expected. I still had a slight tilt on the Jeep due to my catty-cornered parking job (sloping driveway and the street is on a hill). The fill plug was on the low end, probably an inch lower than the drivers side, so I don't think I overfilled it. I'm guessing that a couple ounces seeped out before I realized that it was full and there was probably a few ounces trapped in my little pump. The pump worked like a champ, though I got my forearm workout in getting the oil in there. I pumped it straight out of the gallon jug which I had wedged in a cardboard box with a couple of bricks so I wouldn't accidentally tip it over. I don't see any way to clean the pump out real good so I plan to pop for another $7 and get a second one for the ATF +4 when I do the Power Steering and Transfer Case.
So far, so good.
