replacing water pump
Danalba
bay city
can someone explain to me how to remove the electric fan with the fan clutch together. no idea how to get them out at the same time. i have the fan clutch wrench set from auto zone but cant figure out where to place the pieces to do this. someone help.
wolverine1020
07023 Sorta Central NJ
I believe you have to line up the nipples (thats what I call them) on the wrench with the holes on the front of the clutch.
Not sure if that helps much.
Danalba
bay city
i think i got the wrong wrench set. they gave me one for a car with a water pump pulley that has bolts. i think i need a wrench that is like a Y with two nipples on the end to shove in those holes so i can hold that while turning the bolt. hah so simple idk why i didnt think of that. helped alot. thanks man
wolverine1020
Instead of buying one, see if local friendly mechanic will let you borrow one, leave a credit card or something.
Thats what me and a bud did for his Ram.
BjBnet
Ottawa, Ontario, Canada
you talking about the shroud with the fan in it? There's a screw on each side and the whole thing lifts out once you've disconnected the wire harness and figured the bottom clips on on each side. Then the water pump has something like 8 bolts then the whole thing just pops off.
Here's the How-To thanks to JNaut
http://www.jeepkj.com/forum/showthread.php?t=44066
jnaut
Seattle
I'm confrused here, do you have a mechanical fan? If you don't, and you go to the link BjBnet left (thanks for the props) you shouldn't need to remove the fan shroud at all. Unless they radically changed the fan shroud after 2004. What year is your Jeep?
But your post indicated you do have the mechanical fan. Again, check my how-to out and while there is minimal information (I don't have the mechanical fan), it gives the actual spanner wrench specs and rough instructions to remove.
No way I would be able to replace the water pump on my 04 without taking the shroud off. I do not have the engine driven fan but the shroud goes all the way back to the engine.
jnaut
Seattle
Wha?!! Did they change fan shrouds halfway through the production year? My '04 jeep fan shroud is about 2" deep?
Here's an '06 engine bay which is almost exactly like mine. Note the significant amount of working room.
edit:
But check this out. This picture claims to be the engine bay of an '04 limited:
Now it looks like they actually did change the fan shroud part way through the production year... what's everyone make of this?
rockymountain
Spencerville, IN
edit:
My 04 looks like the first pic. are you sure the second pic doesn't have the mechanical fan?
jnaut
Seattle
I'm not sure at all. Is that the difference? Chrysler sold a larger shroud with factory-installed mechanical fans?
ptsb5a
Northern Alberta, Canada
Dudes, I've got the HD cooling with the engine driven fan. The fan has to come out before the shroud will come out with the electric fan in it. It's a PITA and does require the 32mm(?) thin wrench.
jnaut
Seattle
All I know is that monster shroud is ugly... it blocks off pretty much everything on the front of the block. Man, what, when you change your oil I guess you come up from below to change the filter? How uncivilized.
ptsb5a
Jnaut, you shoulda seen my knuckles after I changed the serpentine belt out. Serious gymnastics getting it over the fan and around the pulleys.
And um yeah, oil filter gets pulled from underneath, just like the drain plug.:freak3:
Ive thought the same thing about those with the smaller shroud. Makes the engine look very small with a wee little tiny baby fan. Plus if I want to get the mechanical fan, given it works with my electric fan, all Ive got to do is buy the clutch and fan blades.
Yes, Ive got to crawl under it to get to the oil filter. Also gotta crawl under it to get to the drain plug so it doesnt really matter.
jnaut
Seattle
Because I've never suffered the indignity of changing my filter from below (what's next, drinking beer directly from the can?!!) I don't know how hard it is. It's up above that cross member and the little oil spillway thingamabobber? The drain plug is easy because it's right down there in front of god and everyone. Kind of like milking a cow. Not that I would ever touch a farm animal...
jnaut
Seattle
Wow, and your fan shroud has the "Light of God" feature on it. I want one of those.
BjBnet
haha, I put that in. My business is Advanced-led.ca for Canehdian customers, or you can reach Mike at bluewaterled.com for US customers and tell him I sent you. It's a 30 LED strip and it's been in there for almost 2 years now. I was concerned with the heat it may not last but the only thing that happened is the silicon casing has yellowed a bit but the light output is the same. All waterproof.
I put 2 strips, one on the shroud and the other at the back as you can see.
Now back to the water pump topic lol
It's interesting to see there are 2 different shroud types for the same year, do you guys know which is the latest, the wide one or the other?
