osufans
Hey all, so I'm embarking on my first attempt at some "clean" body work. I noticed some paint bubbling on the seam along the top of my hatch, just under the high brake light.
Well, I finally pulled the light and noticed paint bubbling under the brake light as well. I'm guessing somewhere's along the way water got in and started rusting it from the inside.
It's some pretty deep rust along the seam. By the time I cleaned it up, I've got quite a bit of work to do. In some spots, the two pieces of metal are no longer welded together, due to the rust eating out the welds.
I'm no body guy...so I'm kinda clueless what to do for a clean fix. So far I've just used a wire-cup brush, and a cut-off wheel to clean out the rust I could get to down to clean metal. I'm sort of limited when it comes to body tools.
Anyways, it would seem to me I got everything down to a good place to work back from. However, it's by no means smooth or pretty. So I have two questions:
1) - Do I need to use something to bond the seam back together?
2) - Is bondo OK to use for that purpose, and if so, what if anything, do I need to do to prep for it?
I'll see if I can upload some pics to my site and link them here.
Thanks!
Thanks!
