Rusty's 2- 1/2in lift
I ordered another set of Bilstein 24-139168 for the front of my 07. I'm going to use them with the Rusty's springs from my wifes 02.
Old springs and new shocks......never would do
You need to match new springs and shocks, weaker springs causes new shocks to wear more quickly, same as old shocks and new springs
When I started doing suspension work back in the 70s I was taught that and then learned the hard way when I did it ( trying to save someone a few bucks ) and had to replace parts again.
170 bucks is cheaper than the alternative.
first&lastKJ
Indiana
Yes I know, but I think it will be good. The Rusty's springs only lost 1/2'' to 3/4'' since 2010.
My 07 still has the original front springs and shocks so I will gain about 2'' from these front springs.
Rev. Mudd may as well give up
Good luck to ya and have a great life
like talking to a smoker, they know smoking is killing them, but by gosh they are going to do it anyways
first&lastKJ
Indiana
Well I did quit smoking in 2010.
first&lastKJ
Indiana
Got the passenger side done today. New moog LBJ, dorman upper a arm, moog lower clevis bushing, wheel bearing, bilstein shock and the 9 year old rustys springs. Added 1/4 inch top plate.
first&lastKJ
Indiana
Done!
Right now 21.5'' both front (pre alignment)
Right rear 21''
Left rear 20.5''
first&lastKJ
Indiana
fullsizerender-jpg.14959
Can't get it aligned right.
I suck at trying to post pictures. This took an hour and I don't know if you can even see it.
JasonJ
Michigan
Did the shop say why? Camber and caster I can get... lower control arm bolts are probably seized, like mine.. but toe ought to be able to get in spec unless your tie rod ends are so wopped out as to be dangerous to drive.
first&lastKJ
Indiana
I reall don't know. I know nothing about alignments. No seized LCA bolts. The tech said I need more positive camber.
I hope the JBA's help.
JasonJ
Michigan
Being that they are longer, they should, yes. What that means is that it pushes the top of the wheel outward, away from the vehicle. Right now, they are probably suspecting that that the bottom of your wheel/tire is out further than the top...
first&lastKJ
Indiana
That is what they said, too much negative camber and no more adjustment. The tech showed me the LCA bolts. He explained how they were adjusted to pull the tire in as far as they would go.
JasonJ
Michigan
Still very odd at your lift height.. I'm 1/2" higher and on stock UCAs and LCAs with siezed camber bolts and mine is still only just, off spec.
kejobe
NE Ohio
Do you have a clevis lift also? if not, you can do a 3/8 clevis for free and it'll help pull the wheels negative also.
kejobe
NE Ohio
Wouldn't going higher would make it worse?
Nope. Not with the way the IFS suspension works. When I had mine aligned, they couldn't get the left front into spec. Was too much + camber. So, i did the clevis lift to draw it -
Do an experiment, strap a board to your wheel/tire vertically with the end just below the flare and put a mark on the end of the board even with the edge of the flare. With the board there, jack up the front and you'll see the board move inward at the flare pulling the wheel more - camber.
Just be careful when you let the jack down if the board is still there so you don't smash your flare with it.
first&lastKJ
Indiana
I have too much negative camber. More clevis lift would bring the top of the tire in more and make it worse correct?
Bandaid repairs ,
you do not change front end specs by raising or lowering the suspension ( well you can but it is not the real way)
There is a "REAL PROBLEM " somewhere
How many 1000s of KJs have had their alignments done at 2, 2.25, 2.5. 3 and up inches with no issues at all,
Go around and talk to suspension and alignment shops and see who actually knows their stuff.
Throwing parts and changing heights is not the " real " solution
Been trying to stay out of this, but dang
first&lastKJ
Indiana
Bandaid repairs ,
I was trying to keep all this in the other thread ''Alignment help''.
I have some current alignment specs from yesterday posted there.
I not looking to change anything else... except the alignment.
kejobe
NE Ohio
Ok. I miss read. L was thinking more neg. was needed. JBA UCA's for lifted should push more positive.
