Selec trac swap
REDACTED
I've got an 05 liberty renegade with a command trac transfer case. I was wondering if anyone had any idea how difficult it would be to swap out for a selec trac transfer case. I live in an area that gets a lot of snow in the winter and I want to be able to have the full time 4wd as opposed to just part time. Would it be as simple as just swapping out my existing transfer case and flashing the computer to recognize the position of the shifter, or would I have to also replace my front and rear drive shafts?
vlad588
Vancouver
I’ve done it it’s not difficult. As long as your new transfer case comes from the car with same transmission it’s an easy swap. No driveshaft replacement necessary. You don’t even have to flash the computer, you just won’t see the “full time” light.
REDACTED
That is awesome to hear. I guess my next step is figuring out what transmission I've got
REDACTED
There are only 3 options and one of them is manual, 4 speed auto is the most common on the v6.
Yeah, after looking in 99% sure that mine is the 42rle transmission. But of a weird one because it was initially designed as a fwd transaxle but they modified it for rwd
klc
“It flies like a truck.”
PNW
You can get your Build Sheet by entering your VIN here:
u2slow
BC
I swapped to the np242 also. Tcase was from an 03 or 04 auto and fit our 6spd just fine. Driveshafts were the same length. Due to dust boot difference it was easier to use the 242's rear shaft.
Shifter is different (swapped that also) and the cable-holding bracket on the 6spd needed some grinding to fit, and a couple zip ties to retain it.
