mindbomb
Went off-roading with the lifted KJ this weekend and it was a blast! This little Jeep can tackle some serious climbs and trails.
Unfortunately I discovered some issues off-roading - mainly a wide variety of annoying noises: (doesn't happen on-road)
Some inspiration pics from this fun weekend - for attention:
Exhaust rub! Bad!!
I can also take some additional photos of the suspension/under the Jeep for tracing the issues. Good KJ peeps your professional feedback/advice much appreciated!
- On every bump and stone loud metal to metal thuds and grinds, horrible - 99.9% thats front stock UCAs are in contact with spring on every droop - can clearly see the marks on the spring - the JBA UCAs will def fix that, right?
- After a while a faint "ringing" noise started every wheel turn - seems like the UCAs bushing are/got shot (there's a visible crack in the rubber) - makes sense it'll make this 'ting ting' noise per turn of a wheel? New UCAs should solve that too hopefully (new bushings). Other culprits also possible?
- Weirdest - I installed the Y-link extension in rear and at full compression the rear right wheel was rubbing against the exhaust!! (or was it the rear UCA/driveshaft?! no idea) BAAADD noise/vibration! Unsure if its related to the Y-link ext/my 1.5" wheel spacers/something else. Whats the solution to that? What should I check?
Exhaust rub! Bad!!
