Finally got around to making the shelf for the rear that Ive always wanted..
Ended up getting a 2x4 sheet of 1/2in plywood, a 1x4 dowel rod, some 1.5in wood screws, and some automotive Grey carpet from walmart..
We cut the plywood to 45 1/2in x 19 1/2in.. The dowel rod was cut to 45 1/2in also. The dowel rod was flattened on one side and then screwed to the edge of the plywood(be sure to pre-drill).
I grabbed a bunch of different types of screws just in case. I ended up using the 1.5in screws:
Table saws makes quick work of cutting the plywood and making a flat side on the dowel:
The edge chipped when we cut it, its good and flat the rest of the way:
We put two screws in from the bottom and 3 more down from the top. All of the holes were pre-drilled:
Ive got some extra carpet that Ill cover up the rest with. I was in a hurry to get it done since it was getting dark:
Materials were under $25.. O
Tell me what ya think! \/
