Something I found on Rocky-Road.com
kjpilot
Minneapolis, MN
Sorry if this is old news that I missed, but it sounds so cool, I had to share \:D/
"Due out in Mid to Late 2006, our new CV axles. While on the surface this may not sound like a big deal, but its going to revolutionize the Liberty offroad market. The reason you don't find lifts over 2.5" on the aftermarket is that anything taller, binds the CV front axles and destroys them. There is one system out there that is taller, but to install it, you have to completely remove your engine and transmission from the vehicle, mount a whole new subframe crossmember system, then re-install your engine/drivetrain. The end result is that you still have to lower the front differential so that there's not more than 2.5" of lift on the axle. Dropping this center section means you lose all the lift you've just paid thousands to buy and install. Plus.... in case you missed it, removing your entire drivetrain is a HUGE pain.
So, our new axles will allow lifts of an estimated 4-6", no dropping of the center axle section, no remounting your engine/drivetrain, it will make extreme height lifts on the Liberty easy. As we said.... this is going to revolutionize the Liberty world!!!" [-o<
