Starter kit
Geralt
FR
Hi,
Just a question.
When you replace the starter kit, what does it contain?
- The barrel and the key.
- The SKIM.
- The PCM.
- Is the BSM absolutely necessary or not?
Thanks
Geralt
FR
In France it is a starter kit.
Geralt
FR
Full kit
Ahh! Now I see, the problem is all the modules are coded to the main ECU, if you replace one the ECU sees it as an attempted theft so it puts the light on the dashboard and blocks fuel injection.
The way round it is to replace all of them with a matching set including the ECU and the matching keys from the donor car.
Or to get the ECU reprogrammed so it accepts a new set of equipment.
Luckily our CRD ECU is very similar to the same age BMW so a lot of the ECU repair companies can work on it.
Geralt
FR
Is the BSM related to the pcm or the skim?
I bought a micropod II and i'm waiting for delivery.
I'm not sure with the BSM, the SKIM and ECU are tied together.
Just a thought & you have probably done it but..... did you use the key that came with the ECU and SKIM that you have fitted to the car? The transponder is inside the plastic bit on the key. The old key will fit the lock but won't deactivate the SKIM.
Just looking at the manual -
The flashing light is showing a transponder fault so it can't see the key!
