Steelies and BFGoodrich Mud Terrain KM3
GBsKJ
So picked up my OEM steelies today,(16x7). Thinking about KM3 mud tires on these in 235/70/16. Pretty much stock size. These will be on a OME927/948 setup. Using tire calculator could change size alittle, but don't want to have any issues with rubbing when turning full clock or bottoming out etc. Should I try to go alittle taller/wider? Here are choices for 16"....
KM3....
927/948 combo will get you 2.5 inches over new stock height
You can go up to a 245-75-16
You will lose some power and mileage of course but will look good
Only thing is you will have to pound over the pinch weld on each side , easy to do and if done right can not even tell you did anything
