Suspension upgrade
Bman0716
Hello. I'm new to this forum and literally have no experience. I bought a Jeep Liberty 2004 32000 original miles. Columbia edition
which I believe is the KJ if I understand correctly. I am gonna fit it with a plow for snow removalamnd don't want to do more than I have to. Need to haul people amd salt inbakck. Looking for recommendations for proper suspension. Don't really want lift, just don't want the plow dragging ground or back bottoming out. Thanks in advance.
Loads of information on here about lifts its one of the favourite subjects, if you do a search one if the guys uses his for snow ploughing too.
JustSumDad
Vancouver Island B.C. Canada
IMO, when you have an older KJ you have sagged worn out springs, likely lost 1" from stock...
ASSUMEING EVERYTHING ELSE IS GOOD!
This is an easy fast fix, just put in H&R 1.5" lift springs with stock shocks (new would likely be good) and new bumpstops.
Nothing else needed. At this age the original bumpstops are likely worn or maybe missing, strongly suggest replaceing them as they are just rubber and they are cheap Amazon fare.
H&R Springs 29203-1 good German steel springs designed to work with everything stock to bump it up 1.5" over stock height.
u2slow
BC
The diesel coil springs are stiffer. Might be an idea.
