So I've looked through the owners manual and for the life of me it doesn't say how much fluid the transmission actually holds, it talks about the type of fluid but I can't see where it says how much it actually holds. 2004 Jeep Liberty has a radiator for the transmission to help cool it down (I guess towing package). I called up the dealer and amusingly enough he couldn't tell me, but he probably didn't want me to do it myself.
I did find this, but I wanted to verify, I'm guessing I have a 42RLE (8.8qts) but I will verify tomorrow with the dealer just to be sure.
https://en.wikibooks.org/wiki/Jeep_Liberty/Fluid_Capacities_&_Intervals
I will drop the pan and replace filter/gasket but I will also disconnect the transmission radiator hose after I refilled and do a full flush for my 200k regime. I imagine I will need about 16qts to do it right (assuming a few quarts are wasted when I drop the pan/refill and the radiator takes 1qt, anything left over will do power steering flushes with)
Another question to those who might have done it does it matter on what type of ATF+4 you use? I can get the Oreilly for $4 a bottle with discount or Valvoline for $5 a bottle, I can also get mopar for about $6.50 but I imagine atf+4 is going to be virtually the same, right? Appreciated.
