Trobow's Lift
Atrus
Metro Detroit, MI
Trowbow -
Just to confirm...
You have OME 927/948's
4 conduit nuts and a 3/8" spacer in the front
2 extra (total of 3 per side) isolators in the rear
Anything I am missing?
What size tires are you running?
Rig looks really great, just getting a feel for what was done and what mine would look like.
Lima.Charlie
Ohio
OME 948's/927's
Rancho RSX 17004's and 17505's
Boilers 3/8 spacer in the front
4 ring clevis
2 extra rear isolators totalling 3 per side
2 pucks per siude in the rear as bumpstops
Spider trax Wheel spacers
The spacers widen your wheel base by 2.5 inches.
Most likely will be pulling a nut in the front sometime soon if it doesn't settle more. Not sure yet. Everyone's setlles differently so, I would plan on four. you can always take them out and it is super easy.
I am running 265/70 16.
Lima.Charlie
Ohio
New front driveshaft greasable U-joint....
dogem
Western Nebraska
Post up some pics with your new tires. Any issues with the spacers and that size of tire ? I will be doing the same lift next month and want to run the 265/75 mt's on the stock rims. Already got the pinch weld taken care of just hope I don't need to trim anything else.
ThunderbirdJunkie
Bronze Supporter
Newport, KY
So what did you do, drop off your driveshaft and have them replace the cvs on both ends with U-joints? And, how much did it cost? Thanks!
Can't speak for Trobow, but they only did one end on ThunderbirdJunkie's driveshaft (the rear joint) saying they've never needed to replace a front joint on a KJ front driveshaft.
bmrrwolfe
North Olmsted, OH
Humm, maybe i should consider this for my bad front DS, gotta find a place like it in Cleveland.
If you don't mind sharing, how much did it run you?
Lima.Charlie
Ohio
~$200
Pictures are of the after portion of the lift....
Be careful about going 265/75.....from what I hear....bad news and loss of power
ptsb5a
Northern Alberta, Canada
What bad news???? I've been running 265/75R16 on my stock wheels and 31x10.5x15 on my off road wheels. Haven't had any bad news with either in the 50+ K miles that they've been on.
resistance
Turkiye
Trobow, that looks really cool.. Also making me thinking of getting shims and rear isos for another inch more..
You know what people who have already lifted want.. More lift;)
Lima.Charlie
Ohio
Problem I had with 4 clevis was I tore a couple of CV boots. Now with only 2 Clevis...I still sit high but no more torn boots.
Lima.Charlie
Ohio
I have had the worst luck recently. My A/C condensor went out....so no A/C and the old womans Stratus needs springs and struts.
