Upgrade Your PCV System TSB#25-001-08
For further KIT information & TSB reference/Instructions See link: http://www.jeepkj.com/forum/f196/pcv-positive-crancase-ventilation-tsb-59367/
These are the parts you will need! Note the new Oil Filler tube does not have a PCV mounted on tube.
54903[/ATTACH]"]
Mine is a 2004..I started this project by...
54905[/ATTACH]"]
Shook out the hoses..oopsie....
54907[/ATTACH]"]
With coolant tank moved up & Throttle body hose moved, slid onto rear coupling first..
54909[/ATTACH]"]
Since you need to remove old oil tube, and remove bolts, now you.."gently"..
54911[/ATTACH]"]
54913[/ATTACH]"]
Don't forget to...
54915[/ATTACH]"]
And Transfer...
54917[/ATTACH]"]
Next is...
54919[/ATTACH]"]
Onto the ...
54921[/ATTACH]"]
Last But Still on the...
54923[/ATTACH]"]
1.25 hours to completion. :gr_grin:
Since the diagrams in the TSB Are Upside down & Confusing...
54925[/ATTACH]"]
This shows the install with ease, even if ya had a few beers!!
(Cheers)
Oh I forgot the best part....that the Kit comes with a sticker !:gr_grin:
I guess since I saved the $225 labor the dealer quoted me.....
54929[/ATTACH]"]
It's now TC Authentic!!! :happy175:
What is the improvement with doing this? Less oil burn off or decreases that sludgy foam that forms?
it's the TSB fix for the foam issue in the oil filler neck.
Tim: do you want to post the TSB notice in this thread too?
No Brian, lets keep this clean and free from poor diagrams / confusion.
Note: SEE post #1 on bottom. I have now included beer friendly DIY guide!! :icon_lol:
Where's the best place to order the parts from?
Just to be clear.
The kit is discontinued but you can but the individual parts listed in the kit which is more expensive than the kit itself.
Here are the parts you would need
53034065AA $13.00
68044349AA $51.64
53020891AE $31.74
5191775AA $0.92
These prices are from moparwholesaleparts.com
Aceofspades
Buffalo
Yea. You have to find them separately and what not. Probably why I haven’t finished mine yet
Eric Suderman
From what I've found the hoses needed are 53032993AF and 53013886AB. Besides that I feel like all you need is a new pcv valve, and a vacuum cap to put on the old valve? I watched a video, I'll see if I can find it.
Eric Suderman
Has anyone else used those part numbers for this update? Has anyone done it with a vacuum cap instead of swapping the oil filler neck? I guess I'll know if it works in a few weeks when parts arrive.
