KJ604
It looks doable to me. You might have to do some hammering on the Jeep as the 4xguards are a tight fit.
That Im ok with as long as all the mounting points can still be used
Wheeling on a rocky trail. They said I wouldn't make it and laughed.... I laughed as I drove out without assitance.What did that damage?
Sorry I'm super late to this!!! 4xguard can take a real beating for the sliders. I have a 2ft long gash in mine to prove it. Only problem is that they fit tight to the rockers for you
Eh, I've fixed worse. You're lucky the damage stayed on the rocker. However you fix it, make sure it's sealed up well from the weather. Letting the elements pack in there will rust the inner rocker area in no time. If you don't go the rock slider route, then a replacement rocker panel is cheap, under $30 plus shipping: Jeep Liberty 02-07 Slip-on Rocker Panel 4 Door
Buying a panel is the easy part. But cutting-welding-grinding-filling-priming and finish paint can be done in less than a weekend.
So I've always been wondering how those 4xguard skids mount. I've had rust issues on the rocker in the past and want to replace the rocker all together this seems like it'd be a good option
That would depend on how long you plan on keeping your Jeep. The skids can hide the rust as a temporary "fix". That will last until the rust finally creeps up and around to the top of the door sill.
Well the plan was to just cut out the rocker take care of the rust underneath and put the skids in place
I may do that seeing as how if the rust got bad enough I was gonna weld in a piece of rectangular tube steel
