window regulator I think
Tog
AU
so my drivers window seems to have failed. I can hear the motor going but nothing happens. It made a horrible grinding noise then the window started sliding back down. Is this a likely regulator or something else?
2004 3.7 limited
Tog
AU
cheers I looked this up as mine is Aussie vehicle I need right side not left side. couldn't see any listing for right side only left.
2004 3.7 limited
found the kit for the other side I actually bought the pair as the left window has made horrible noises since the day I bought the jeep .
2004 3.7 limited
chanwmr
Upstate NY
While you're at it, replace all of them. If one goes, chances are the others are about to go as well. For about $100, you never will have to worry about them again.
Damotee
Cape York, Australia
1A Auto have a great video on Youtube on changing the window regulator motor in the Jeep KJ. I did mine last weekend.
Tog
AU
installed the drivers window kit tday will do other side when I have more time. Great kit fairly easy to install it's all steel so it won't deteriorate. the screw like cable on the oem goes into a plastic sleeve that had just cracked and broken releasing the cable. the motor works just fine why replace the whole thing with another that will do the same with age.
2004 3.7 limited
mtshasta
Mt Shasta, CA
2004 3.7 limited
Hi Tog, where did you get the window regulator kit that has steel parts? Thanks, MtShasta
nbas
Greece
I replaced all 4 last year with metallic ones for 72$ from ebay. The OEM are plastic and finally brake...
Since then, I do not have any problem.
