window regulator ?
MARINEMP
PA
So I think I have a bad window regulator my window just falls down the track and the motor just spins I saw a cord come up out of the window ? Idk im assuming this is the problem . Whats the best/cheapest way to fix this ? Its my front driver side window BTW.
termin8ed
Fowlerville, MI
What year is your jeep? There was an extended warentee on some of them and a repair kit available. Lift plate with drive cable. Need to know if you have a pin on glass style or not
wheeee32
Not the mountains.
It isn't too hard to fix once you replace that plastic piece with a nice metal one like the Steiger kit that was mentioned.
Steiger has lifetime warranty.
Here's the directly to the front window regulator repair kit
Steiger Performance - Jeep Liberty Power Window Regulator Repair Kit
However, note that it costs $100
The one I posted previously from amazon, I just recently bought a rear driver side from the same seller. $30 for 1 year warranty.
Also all metal design as well, steiger rip off basically.
Up to you.
I also used teflon grease on the rail after cleaning it up.
Finish Line - Bicycle Lubricants and Care Products - Premium Grease made with Teflon® fluoropolymer
CobraNutt
Salt Lake City, UT
I've had the "knock-offs" on the front windows of my Liberty since May of 2012. No issues, and I didn't spend $100/side to fix them. Mine were less than $50 for both sides when I bought them. As mentioned, the choice is yours though. And yes, good lubrication is essential. :)
MarkJ
Which ones and where did you get them?
Mark
rockymountain
Spencerville, IN
The Steiger kit won't fix one that has a broken plastic tube and the worm coming out. That's how both of my fronts failed. The plate was actually still in pretty good shape on both. The one from rock auto is working good in my drivers door. It came with a nice motor making it faster.
Edit: Dorman is the one I got.
MarkJ
I am sure there are some on here who will value that link. Nice to know when something reasonably priced works good.
Mark
chanwmr
Upstate NY
I got mine from Auto and Art too. You can go through eBay or directly buy from their site. You can buy one, two or four. Take your pick. The parts are very durable and they are very easy to work with (they sent me a replacement without sending the part back when a screw was missing in the package). The only issue maybe the little screw that they provide being too short but that is very minor. I have had good luck with all of the parts so far.
jsapko
Prescott, AZ
I've replaced three window regulators on my '05 KJ and need to replace a 4th (front passenger). I used bought mine from 1AAuto.com for about $70/each.
Search Results for window regulator - 1A Auto
They also have installation videos that help a bunch.
