Write off? Or worth getting fixed?
Lib88888
Rust, lots of rust. Bought a 2007 liberty sport 2.8 diesel, 110000 miles. Engines perfect, everything’s great until I noticed rust on the rear arches. I’ve followed the rust down and it appears to also have affected the sill. The right hand side of the jeep is worse than the left. (This is the only rust on the car) please help
That's fairly normal, they all go there. All the outer panels are available, the inners are simple enough to get a sheet metal shop to fold for you, I had mine made from 2mm sheet, bit stronger and lovely to weld. Make sure you get it wax injected once it's done otherwise it rots from the inside out.
Lib88888
Thanks so much guys! I’ll get the parts ordered and have them welded on. With wax injecting afterwards is this something I can do myself? How is this done? Thank you
