Thank you for replyin Dad0Six.Congo -
you need to break this down a bit.
trying to read into your story - you changed plugs and coils. Truck did or did not run before ? not specified but Now, definitely no start.
since the engine cranks, spray a bit of brake clean into the throat of the throttle body and crank again - Fire up but dies down? No fuel. Crank, but no change, no spark.
If crank, no spark, did something happen to set the security module into theft mode? If is sets, no spark, no fuel.
Signal wires would be +12v, +5v PCM, PCM ground, Ground. A light is not going to tell all.
I'd plug the PCM back in until you can help us with enough detail to follow what led to all this and where we are now.
Duralast. ( what i could afford)Much better now!
I admit to being a bit stumped at this point. Q: on the coil packs you used - what brand?
You will find on these jeeps, that they are very picky about sensors and the like. For coils, OEM or Standard Motor Products are preferred. Any chance you still have the old coil packs to swap back in and see if you can get a running jeep?
Cam, Crank, TPS, all would be preferred Mopar, except in case of emergency to get home.
Thinking about your coils tho - What is the chance that you displaced a pin or 6 when putting the connectors back on? Another thought - on these 3.7, there are ground straps from a single point on the firewall to each head. Braided aluminum corrodes, but looks good. A favorite old trick is to run a jumper cable from Batt Neg to a point on the block or head. Try to start - Yes ? You got a bad ground somewhere.
Re the theft mess - there is a red light on the dash. Just a little red ball. If it is on, the jeep is in theft mode. Isn’t going to run until it is solved. Most of these had some theft deterrent from 04 up. My 06 has a tombstone head key, the 04 has a black key and a grey key.
The starting fluid tells you that the ignition side is working and points to a fuel problem.
When you go key on, do you hear the fuel pump run a few seconds? Do you have access to a fuel pressure gage to put on the fitting on the rail?
Again - very odd that the coil packs killed it. GOtta be something simple, but you changed so much at one point, it is not clear where we are broken down. BTW - new parts can be bad out of the box.
Let’s keep digging at this!
