BDS Suspension
I bit delayed on the build progress from last week while I was out in Moab for EJS, but BDS R&D had some time to continue progress on Project KJ. We were able to chat with a number of companies out in Moab and pitch our idea to them to see if they are interested in helping out. We'll have more on those parts as parts arrive.
To make room for the massive tires we plan to run on this Liberty, we needed to make some room in the fenderwells. R&D took a plasma torch and sawzall to the inner fender up front removing nearly all of it. Front there the unibody was plated and the end result looks similar to a frame rail for us to start mounting suspension brackets. We'll be building a new inner fender in the coming weeks and plan to tie in a coil-over mount and engine support to retain the rigidity this Jeep's unibody had from the factory.
For axles on this project we decided to build up a set of JK Rubicon Dana 44 axles. While there are plenty of axles on the market, (i.e. Currie 9, Dynatracs ProRock 60s, Ruff Stuff fabricated housings, Spydertrax Spyder 9s, etc.) we wanted to utilize and axle that is attainable to the masses and show it can be built up to survive off-road abuse. The JK axles have a track width of 65'' (over the stock 62'') to help us gain room to mount the coil-overs, steering assembly and allow the larger tires to have a full sweep from left to right. To fine tune the overall track width for the stance we want we'll find a wheel with our ideal backspacing. At this point we've stripped the brackets off our JK axles and have them in place to begin mocking up tire size, wheelbase, and height. We're using a set of 40x13.50 Maxxis Trepadors on 17x9 (5'' BS) steel wheels we had laying around the shop for mockup. In keeping this Jeep as low as possible, potentially running 3-4” of lift with plenty of droop from a linked suspension we will begin mocking up suspension geometry using a set of 14'' Fox remote Reservoir Coil-Overs that we have in the shop. The decision is still out whether a set of 12'' C/O or 14'' C/O will be better suited for this build and the performance we're hoping to attain, stay tuned for more in the coming days as the guys continue to prep this KJ. Check out the blog for all the info on this build at Project KJ Archives » BDS Suspension Blog
