Project to divert KK coil to KJ
Hopefully good quality, Denso gear is usually decent. Unfortunately the Chinese are buying old names and making cheap junk to go in the box, I got caught with a Crossland filter.
ikuo78
Japan
surely.
I also end up buying low-quality products without checking.
Manufacturers with IR on their HP are generally fine.
ikuo78
Japan
I replaced the serpentine belt because I smelled rubber from the engine compartment.
The belt had many cracks.
It was a different part number than the service manual.
For the 2003 model, the service manual lists only one belt option.
Maybe someone replaced it?
I don't know the correct length, but the belt is 2225mm, and the tensioner is working and working properly at the moment.
ikuo78
Japan
When I replaced the serpentine belt, I noticed some play in the water pump, so I replaced it without ignoring it.
I was unsure about the belt length, so I drew a line at the belt tensioner's limit position (24mm before the stopper).
In the end, the belt was too long, so I replaced it with a 2200mm one.
before belting
After putting on the belt
