Bilstein ome lift bushings and metal sleeves?
r00t2400
I’m in the process of having my 2011 kk lifted with ome coil springs and bilstein shocks. The back 660 shocks I’ve read in a few places need hardware that’s not included. I found this list on here, is all of this needed or just the metal sleeves? I read on a post that the sleeves are required but didn’t see anything about the orings or other stuff listed on this paper.
r00t2400
This is the part number for my rear bilstein shocks. 24-185660
o rings are just there to keep some moisture out, Ive installed them both ways with no ill effects
r00t2400
What about the stainless steel sleeve? I’ve seen you get a bit fired up about said sleeve on this forum but I’ve gone to numerous hardware stores and called several specialty fastener shops in my area and have yet had luck finding them. One shop said they’d get back to me with a lead time. I have zero mechanical knowledge so apologies for my ignorance on the subject. The tech said he’d use the old one but I found a thread that said the old one was too skinny. Finding an od of .625 was easy the id of .470 was the tough one. Several replies that they could get close but I read where you said it needed to be snug so I sssume close isn’t gonna cut it. Off to a second ace hardware to see what they say.
r00t2400
I told every place I have the od of .625 the id of .470 and the length of 1.825. Most places didn’t even seem to have an ability to plug those numbers in.
EagleKJ
Lurking member
Toledo, Ohio
Bring the bolt up to the hardware store and find a piece that fits snug. It may not be exactly .470. That's what I did then I cut it to the length I needed. You should be able to find something close that fits snug.
r00t2400
Cool thanks, ace hardware guy, “I wouldn’t even know where to start” lol seems to be the reaction everywhere I go.
r00t2400
Wouldn’t say this is snug would you? Not long enough even if it was. That’s the closest ace had. Onward!
r00t2400
I’ve now called and visited over 20 stores and companies to no avail this is insane.
Think you will get a better response from a machine shop, wouldn't take long to make a set to you dimensions.
EagleKJ
Lurking member
Toledo, Ohio
Yes you are not going to find something to those exact dimensions. The ones I used were a little under half inch maybe .485 or so piece of pipe and I cut it down myself. I don't think the length I used was 1.825
