Thoughts? OME lift Bilsteins falken wildpeaks 265/70/16
All the JBA ball joints are the same across all models of their UCA’s, so I doubt they are wrong. What is the issue the tech sees with them? The rubber boots can be pulled down flush with the top of the knuckle and filled with grease.
Mine:
r00t2400
He was
Mine:
he was thinking that the post of the ball joint or whatever it’s called should be further thru the hole so there are threads showing like in this picture
r00t2400
Mine:
Did you watch the clip I included does everything look ok to you?
r00t2400
Mine:
I guess it does look pretty identical to yours.
Sorry, didn’t realize one of the images was a video. I watched it now, and the ball joint stud seems firmly seated in the knuckle. There is no up and down or side to side movement possible there, right? If it’s secure, I would say you’re probably ok.
I am not sure what the tech thinks could be wrong. Perhaps on a stock ball joint the stud is shorter so the A Arm might sit closer to the knuckle? But secure is secure.
He was
You and I both have KK’s and Johnny O (left hand pic) has a KJ. I think our knuckles have beefier, thicker receivers for the ball joints. I’m thinking his shows threads under it because the metal is thinner.
If it helps set your mind at ease, I’ve been running JBA upper control arms and a lift since 2013, when my Jeep had 60,000 miles on it. I now have 206,000 miles! I have had to replace upper ball joints once on one side and twice on the other during that time, as they have worn out. Replacement is a breeze since the ball joints can be unbolted. No removing the UCA or pressing anything in or out. I think you’ll be very happy with this upgrade.
r00t2400
I spoke to marlin and he asked me if it measured 4inchs from the bottom of the support to the end of the bolt. He included this diagram. Said if it doesn’t it’s prob the wrong ones and he’ll need to ship me new ones. We measured and it def seems off but mine looks very similar to other pics I’ve seen here. Does yours measure four inches? Here’s the video of measuring mine.
JBA included a bushing for some time, not sure about now
Main thing for the bushing was to keep the boot compressed more
I tested , among other things for JBA, on the 03 and 04 by running one side with bushing, one without, same results really in overall performance , wear, service etc
MANY MANY so call 4x4 experts out there installing lifts who know nothing except working on solid front and rear diffs so they get it wrong
r00t2400
I sent video Of the measurement of the ball joint from the support to the tip and I guess somehow it’s the wrong size. They shipped the correct one this morning. Yikes, solid customer service at least!
JBA usually gets an A for customer service. Marlin is the owner of the company! Glad you got answers and a new set of ball joints that will work.
r00t2400
kinda strange he sent me the same ones we already had. Guess I got some spares, the whole situation is kind of strange tho. He seemed to think from the measurements I took that they were wrong and then sent the same ones. Someone else commented that all the ball joints they use are the same size so I’m really not sure what ef is going on.
I think that was me who said they were the same. I misspoke on that. They are the same for the KK and the KJ, but not necessarily other models. The website asks for a specific model when ordering.
r00t2400
Do you think I could get you to measure your ball joint from the bottom of the support to the tip? Like this if it’s not too much trouble…
r00t2400
All good I kinda figured what ya meant. if ya get a chance to measure it’s actually from the under side of the housing to the tip of the stud marlin says should be four inches. No sweat Tho.
I’ll check it out for you tomorrow. Just to confirm, you mean the face of the ball joint where it bolts to the top of the UCA, to the tip, right? Since there should be no difference KK vs KJ in the ball joints, this should be the info we need.
duderz7
Weiser, ID
Keep in mind the measurement could be skewed if the stud isn't straight in the housing. I'm pretty sure you have the correct ones, well 2 sets now. JBA customer service is just that good! There was a slim chance you got the incorrect ones and JBA didn't hesitate to send another set.
r00t2400
If you click the pic and make it full you can see how marlin describes how to measure it and he draws where to measure also in green.
r00t2400
This is a video of the tech measuring it. I believe marlin meant the first measurement he takes from under which measures around 3.5. Kinda strange he said it should be four which is why I’m hoping to get someone else to measure theirs.
