Broken sway bar link bolt
My extended JBA sway bar links were from 2014 and were making my a ton of noise. I found sway bar links to replace them from Teraflex for lifted JK’s. They’re a little shorter but they will work fine. Still longer than stock.
I was able to remove the old links and the sway bar itself, and remove the old 2008-era bushings. I have Moog bushings to take their place.
This is my problem right now.
I broke the head off of that bolt. I have been soaking it in Kroil and have two nuts on it, hoping to be able to break it free. It will not budge. I am looking for other ideas.
Keep in mind how close to the fuel filler hose this is…
… so I am a little hesitant to use fire or a welder here. Is it far enough away to be safe? I would prefer to try other ways first. I am all ears…
Thanks in advance.
P.S. The upper shock bolts are going to be the same way. They will not budge. I haven’t broken the heads off them yet though.
Luke
Interloper
Bancroft, Canada
Heat FTW! If you don’t want to risk it or protect the lines with something you can try a small butane torch (lighter on steroids) so you are better able to control the heat. This worked for me when I was too close to brake lines.
Luke
Interloper
Bancroft, Canada
You should find one at any convenience store … they are refillable. They come in many degrees of unnecessary. ;)
Oh that’s interesting. Looks much easier to control. Can I get an 18 mm grade 8 bolt nice and red hot with that?
Luke
Interloper
Bancroft, Canada
Butane and propane have about the same (air) temperature. You just have to spend a bit more time as the flame is smaller. It’s definitely a less frantic operation as a result.
Yeah I have been looking at getting a Bernzomatic torch with an adjustable flame and Mapp gas, but it seems like it might be a little too unpredictable for this particular situation. It is probably not a bad idea to have one at some point though. I like the little butane torch idea for this.
Jeremy-WI
Home
There isn't any MAPP gas left, it was discontinued years ago and the MAP Pro isn't what MAPP was
Luke
Interloper
Bancroft, Canada
At worst it’s probably a $5 experiment, including a can of butane that will last you forever. ;)
It worked on my rusty brake line fittings.
Just make a shield from crumpled tinfoil for the lines, they are several inches away so it's only sparks you need to worry about (** as long as you can't smell fuel around there! **)
I'd have no issue with welding a nut on the broken stub.
DadOSix
Cumberland, MD.
Perhaps a friend with a portable oxy/acetylene setup could get it hot enough.
Dont neglect the old warm bolt melted crayon trick. Press a crayon on the warm threads and let it penetrate. Gets in where even pb blaster fears to tread.
Welding a nut on will be my plan B if heat doesn’t work. But hoping it will!
With how close those lines are I'd rather weld a nut on than blast a blow lamp in there, the welder will only heat the broken stub up.
AFT2008KK
Can you get a stud remover on the bolt thats left? Or perhaps one of the electric coils that heat up the broken bolt? Both can work magic togther?
Just ordered a magnetic induction heater! It arrived this afternoon and I’ll try it out tomorrow. This I think is maybe the best option near the fuel filler hose, directed flameless heat! Kind of pricey but I see all sorts of future use for this thing. I not only have the 08 Liberty but also an 07 Commander now. There will be a few seized nuts and bolts, guaranteed.
