Make sure when replacing the bulb to wear gloves, making sure that the bulb does not come into contact with oils on your hands, in your car, or elsewhere, as this can create weak spots on the bulb that cause it to break very quickly. Higher quality bulbs sometimes even come with gloves for this very reason. Other than that I'm not sure07 Liberty rear driver side brake light keeps burning out 3rd time replacing it in a month,any idea why it keeps doing it? Thank you.
Ok thank you. I will do that next time I replace it which will probably be sometime next week it's been doing this about every 2 weeks,it turns milky white and it has a hole in it.Make sure when replacing the bulb to wear gloves, making sure that the bulb does not come into contact with oils on your hands, in your car, or elsewhere, as this can create weak spots on the bulb that cause it to break very quickly. Higher quality bulbs sometimes even come with gloves for this very reason. Other than that I'm not sure
I don't think so I replaced the whole tail light assembly a few years ago because of electrical problems and never had a problem until nowAre you certain that water isnt getting in the housing?
Not that I can see everything inside looks dry and no water standing but I will double check the sealLooks like water's getting in.
