bigBlue
Has anyone removed the stock bump stops from the front end. I want to get a set before i throw on my version of the fankie, but I cant figure out how to get off the originals.
They pop right back in same pocket
Hmmm, I used a 2x4 but I must not have eaten my spinach that day Anyway like Digger said a little lube makes things much easier - it doesn't take a lot either, just a thin film of silicon or other lubricant will work.Use a 3' 2x4 as a lever, using the tire as support. Then you'll push them in with ease.
...but you must eat your crispies...
Ok.... so maybe it's just me... but I can't get the stock bumpstops out.
I've pried and pulled and they have moved almost nothing at all. Is there a special trick to this? Or have mine just decided they want to give me a hard time today?
