CD Changer making clicking noises w/no CD's in it Can I reset?
GitEmSteveDave
Howell
I brought my car in for a new water pump. When I got it back, instead of the "normal" soft whirring noises on startup and turning the radio on and off, I got clicking. I've never put a CD in it, so as far as I know, there were none in the changer. I decided to try to put a cd in to see if that might clear the clicking, but I can not push a CD in. I also tried holding the load/eject button in case maybe that did something. Is there a way to "reset" the radio? The radio works fine, and that's all I listen to, but the clicking is driving me crazy because it sounds like it's destroying itself from the inside.
I've tried disconnecting the battery and touching terminals for a few minutes, but that didn't seem to do anything.
That's what my headunit did when it died. Ended up replacing it. It's the CD player that makes the noise - you might be able to take the headunit out and disconnect the CD player.
GitEmSteveDave
Howell
Of course it waited till it was at the mechanics to do it....
Can I just get a junkyard changer and swap them? With the Renegade's chromed accent panel, it's not "simple" to use a double din kit, as they only seem to come in black.
Will I need some stupid code from the dealer to make it work if I do a swap? I know some makers do that to combat theft.
Phuc Nguyen
I put up with this issue for a few years until had enough with the annoying sound everytime the ignition is turned on, and decide to work on the issue.
This annoying sound is due to small plastic gear inside CD player is broken/missing teeth.
There is a replacement CD player unit only available on eBay for $35. You need to remove your entire CD/radio unit, unsoldered a few points and soldered a new unit in.
Voila... your CD/radio unit is working as new.
Note: you need to look at your unit face plate for a model letter, i.e. like RBQ or RAQ, or some letter like that.
GitEmSteveDave
Howell
I only listen to terrestrial radio, so I really don't need the player to actually work. I learned to deal with the whirring it did/does, but like you said, the grinding is just way worse. I also turn off the radio when I'm driving, rather than turn down the volume, so I hear it a lot.
Phuc Nguyen
You cannot bypass CD mode, due to the unit is trying to re-home.
BTW, there is no CD mode option when the unit is not working properly.
GitEmSteveDave
Howell
Well, if I took it apart and removed the CD changer unit, as opposed to replacing it, would the radio still function AM/FM wise?
Here is my radio:
Phuc Nguyen
Here is my radio:
Yes, 6 disc CD player is a seperate unit by itself. Just de-soldered and re-soldered a few points and done, instruction came with the unit. Check this site for more information.
https://www.ecrater.com/p/31997291/...MIw8qUlYK45wIVdh-tBh19iwiwEAQYByABEgJW-_D_BwE
GitEmSteveDave
Howell
So if I go and get a entire used unit, will I have to enter in some code, or have the dealer do it? I know a lot of makers put that in some of their radios as a anti-theft feature.
