diff fluid
Whats good oil to be putting in the front and rear diffs? can I use the same one that goes in the transfer case? is Draining the front the same as the back?
I use either Royal Purple 75W-140 or Mobil1 75W-140 gear oil,both very good.
You can not use ATF+4 in the diffs.The front diff has a drain plug(8mm allen)and a fill plug,no removal of the diff cover since a diff mount blocks the way.The rear diff you must remove the cover to drain,reseal with RTV and fill using the rubber fill plug on the rear diff cover.
Vtolds
Stowe, VT
So ATF+4 in the Transfer Case, and 75W-140 in the diffs? just so I have it straight.
