Is this the end of Liberty?
ME72
2005 Jeep liberty Sport 3.7 4wd. Has 140k Miles on and I noticed the Anti freeze was low. Filled it. No water in oil. Ran fine until White smoke poured out tailpipe while headed up to Eisenhower tunnel. My research, and from reading this forum, I have discovered that the 3.7 has a tendency to blow head gaskets, crack heads, blocks. Knowing this I have changed the oil religiously to ensure no sludge and to avoid the oil galleries getting clogged as I hear that happens
I had it towed home. Getting it taken into the shop. From what picking the brains of mechanics friends tell me its likely the end for this otherwise well maintained and running vehicle. Any thoughts?
Probably a head gasket leak. Doesn’t have to be the end of the Jeep at all. Resurface the heads, install new gaskets, and keep driving it.
hotpepper
michigan
Head gasket leak is a common problem of the 3.7 pass 100k, just resurface the head and get a new gasket. The most critical part is get a good reputable shop to do it! Sloppy replacement will bring endless troubles.
2 jeeps
We had the same exact symptoms, in a high mile 2002 renegade. I took the heads off had them serviced, reassembled with new gaskets and timing chain replacement. All is well so far. The unexplained coolant loss was hard to take. I may have posted some pics to the shinny pistons top on the effected cylinders. Good luck
KingKJ
The Rock Spotter
Utah
This is what the inside of some of my pistons look like for reference about the head gasket, I have a leak, and am getting the white smoke out of the tailpipe which is the coolant being burned/evaporated and pushed out the exhaust. I don't have the oil and coolant mixing which is just a matter of being lucky enough that the break in the gasket is between coolant and cylinder and not between coolant/oil.
Definitely not the end of the vehicle, it will just cost a bit to repair which is why it usually is the end as shops charge so much money to repair it that it isn't worth it, I'm doing the work myself so I just have to buy parts, but shops charge a lot of money just because of how much work it is to do it.
