Is this the end of Liberty?
ME72
2005 Jeep liberty Sport 3.7 4wd. Has 140k Miles on and I noticed the Anti freeze was low. Filled it. No water in oil. Ran fine until White smoke poured out tailpipe while headed up to Eisenhower tunnel. My research, and from reading this forum, I have discovered that the 3.7 has a tendency to blow head gaskets, crack heads, blocks. Knowing this I have changed the oil religiously to ensure no sludge and to avoid the oil galleries getting clogged as I hear that happens
I had it towed home. Getting it taken into the shop. From what picking the brains of mechanics friends tell me its likely the end for this otherwise well maintained and running vehicle. Any thoughts?
Probably a head gasket leak. Doesn’t have to be the end of the Jeep at all. Resurface the heads, install new gaskets, and keep driving it.
hotpepper
michigan
Head gasket leak is a common problem of the 3.7 pass 100k, just resurface the head and get a new gasket. The most critical part is get a good reputable shop to do it! Sloppy replacement will bring endless troubles.
KingKJ
The Rock Spotter
Utah
common past 100k... makes me glad mine lasted until 225k as far as I know(no previous paperwork for head gasket repair from previous owner)
2 jeeps
We had the same exact symptoms, in a high mile 2002 renegade. I took the heads off had them serviced, reassembled with new gaskets and timing chain replacement. All is well so far. The unexplained coolant loss was hard to take. I may have posted some pics to the shinny pistons top on the effected cylinders. Good luck
