Flowmaster was $100
http://youtu.be/Rqqr5WAC-CQ
Spray paint the rims cost $20
Paint the entire under carriage cost $10 for a quart of paint and a brush
Big three electrical up grade used some left over 4ga practically free
Free decal stickers anytime you buy something
Like the flowmaster came with a bunch of stickers tire rack sent me stickers too so freebies
Plasti dip is cheap can flat black anything i hit the gas tank flapper thing looks cool
Notice any improvement from the big3 electrical upgrade? I know that on some vehicles, it's night and day... others.. meh.
If you upgrade to a bigger alternator you will need to get a external voltage regulator. Also the problem with voltage stability may have to do with the crappy internal voltage regulator.
I have a total of 230 amps of fused items running on the stock alternator and one battery and I have no problems but most of the large items that draw a lot of current are never on at the same time.
You can use the existing internal voltage regulator when you upgrade but if the voltage jumps every where you should install a external voltage regulator. You should also install a voltage gauge so that you can monitor your voltage and see if you voltage jumps around. Having the external voltage regulator has stabilized my voltage.
Another key to having a good charging system is to have a good battery, I am running a diehard platinum I think group 34/78. Having a good battery will keep your libby starting and running great and it will also put less stress on the alternator.
It cost about 225-250 depending on what sears you go to.
For less than $100 i got a spare tire bracket extension to push out my spare tire so I could close my hatch with my bigger tires![]()
Offered you one for $50 - did you get it cheaper?
Yes I did. I was about to message you when my shop called me and said they had a bracket they pulled off of a JK (changed out to a swing tire) and said the owner would part with it for $20 so I couldn't resist it. Sorry =\
