Front LCA bushings replacement
CheapJeep'n
Hi,
First time poster long time lurker.
I have a 2003 Jeep Liberty Limited Edition and the front lower control arm bushings are starting to look a little rough, especially the bushings where the clevis attaches.
Hopefully I don't need to replace them too soon but I like to be prepared since I daily my KJ and I can't have it side lined for too long.
I've already purchased 3 replacement bushings for each arm (Moog K7389 and Moog K200258) but after reading some other posts about pressing out these bushings I'm a little hesitant to do so.
I don't have access to a shop press so my plan is to use a ball joint press (Astro Pneumatic Kit 7897) to press out the old bushings and press in the new ones.
From what I've seen people seem to have to drill holes in the rubber and press the inner sleeve first, then the rubber, and then finally the outer sleeve.
For anyone whose done this job before, how was it?
Did you need a shop press or were you able to use something like a ball joint press?
I know the Factory Service Manual wants you to use a few special kits to remove the bushings (Miller 8858, 8830, and 8839 for the threaded rod), but I don't see why a ball joint press kit wouldn't work.
Thanks,
Your plan might work, depends how powerful the ball joint press is, the bushes can be very tight. The old trick to get them out it is to drill round the steel center and chop it out to make room to hacksaw split most of the steel sleeve, don't go all the way and damage the arm, then fold it in and split it with a chisel.
I'm eyeing up polyurethane bushes for mine, not many available here so looks like a lathe job.
^^^ This. I did mine two summers ago but first I found an old but good shop press for sale on FB Marketplace or Craigslist. I also used the attachments from the ball joint press kits along with the shop press to be able to press out the centers of the old bushings and to press in the new bushings after I cleaned up and repainted the arms.
CheapJeep'n
Thanks for the replies.
I would love to have a press but I don't have anywhere to put one at the moment.
My LCA's look to have been replaced at some point so I'm hoping the bushing sleeves wont be too stuck.
I purchased the car from an auction at the end of 2017 so I know they're at the very least 8 years old.
I thought about just replacing both arms with new already assembled arms like this Mevotech Supreme but I'm hesitant.
I did replace the front upper control arms last summer with Mevotech Supreme control arms and they've been fine so far but I'd prefer to keep the current lower control arms if possible since they appear to be Mopar replacements.
If you get stuck then you can always take the arms and bushes to a garage and ask them to press them out and in, shouldn't be too expensive, the labour is removing and refitting the arms.
CheapJeep'n
That's true.
Yeah I'm hoping the camber/caster bolts come out without a fight, I've seen a few posts mentioning they were rust welded to the inner sleeve and had to be cut off.
I'm planning on installing these Moog Grease-able bolts , anyone have any experience with them?
I know the hole drilled in the center technically makes them weaker than a solid bolt but I think it's worth the trade off to get a little grease between the bolt and the inner sleeve.
I don’t have a dedicated workspace for mine either. I drilled the feet and installed wheels so that I can roll it to the front of the garage when I need to use it. The wheels have parking brakes so the thing is stable. Here it is pressing out the center of a LCA bushing.
Seized bolts inside the bushing sleeves can be a fact of life. One camber bolt and one clevis bolt on my LCA’s were like that and I had to cut them out. I did a bunch of damage to the LCA with the grinder and had to find a replacement from the junkyard. Then I wized up and used a sawzall for the other, which is much more controllable. The Milwaukee “torch” blades are worth the extra money cutting the hard steel of these bolts.
CheapJeep'n
Yeah with my luck I'll probably end up having to cut all 4 bolts.
Can I ask what bolts you used to replace the cut ones?
New camber bolts are available. Be careful with grease around the bushes, it attacks the rubber. Polyurethane is better if there is oil or grease around.
I opened my wallet and got Mopar replacement bolts from the dealer. I didn’t want to take any chances on safety with something this critical.
CheapJeep'n
I may end up doing the same.
However I have to say I haven't been overly impressed with some Mopar parts I've gotten over the past few years.
For example, I had to replace the transmission pan last year due to the old one rusting out and leaking.
I decided to go with the Mopar pan mainly due to wanting an exact replacement so there wouldn't be a difference in transmission fluid level on the dipstick.
The pan itself wasn't bad, but at almost double the cost of an aftermarket pan I was disappointed to see imperfections like sharp edges and missing paint spots.
I also recently got a replacement Mopar belt tensioner and similarly it had some sharp jagged edges and metal shavings that I discovered when I ran my finger against it, had lots of fun pulling metal splinters out of my finger.
Also the pulleys were both plastic, not steel like the original, probably not an issue but again for the price I think they could've splurged and put some metal pulleys in.
That isn't to say Mopar parts are terrible, I just don't think the exorbitant prices are always justified.
24turbo
Alberta Canada
As stated above use a sawzall with Torch blades. And use a TON of cutting oil. Its messy but the bolts cut much faster and you will use less blades.
Shankster
Durango, Colorado
I decided that replacement control arms were inexpensive enough that it wasn't worth messing with pressing the bushings in and out. If you plan on having a shop doing the press work I'd call and ask for pricing first. I had a shop press bearings in and out of a Subaru knuckle once and it cost more than if I'd just bought the knuckle / bearing assembly from the dealer.
I'm setting up to do the rear arms front bush, torn again so this time I'm going to polyurethane and instead of hunting for the proper ones I've made it harder by buying Landrover radius arm bushes so I will have to weld a new tube into the arms to take the slightly smaller diameter. A pain but a bag of 4 bushes is £25 instead of £80 each shipped from Poland. I'm not bothering putting Chinese rubber bushes from Ebay in again.
CheapJeep'n
Yeah after thinking it over that's what I'm going to end up doing.
I'm going to get the Mevotech CMS25152/CMS25153 arms, with shipping it comes out to around $300 shipped.
I replaced the front upper control arms with Mevotech supremes last summer and the quality was decent for the price.
I'll post back after I change them out and let you all know how it goes, hopefully my old control arms have a little more life left in them.
Hec In Omaha
Beaver Lake, Nebraska
FWIW, I recently replaced my 2009 KK’s LCA’s with Moog units. The Moogs appear to be higher quality than the OEM LCA’s. I like that the ball joints are greasable too! The ride is great!
Mangate
Mexico City
I used polyurethane "Super Pro SPF4019K" for the LCA bushes, bought them in the UK, but they are made in Australia. Very expensive though at £210 for a set of 4. I have a press, but I can't remember whether I used it or just a ball joint press. I did get the proper miller tool though, used off ebay.
