Front Suspension Top Plate Availability
tyates007
Time to replace the suspension on my 2004 KJ. Decided to go with OME components and will upgrade UCA with JBA as well while I have it apart. Wondering if there is a company still making the 1/4” top plates? Search is coming up with not much. Only place I have found potentially is Rusty’s Off Road. Thanks to this group I have the other component in the shop already waiting to install. Top plate not required but thought I would ask.
  • JBA UCA
  • OME 927 front springs
  • OME 948 rear springs
  • OME 90009 front struts
  • 6 conduit nuts 2”
  • OME N132L rear shocks
  • 4 hockey pucks for rear
  • 4 upper rear shock isolators
  • 2 3/8”x2 1/2” bolt with lock nut and washers for hockey pucks
  • 2 Teraflex 1903200 bump stops for front
Search for
Boiler's 3/8" shims or equivalent?​
On here and you will find it, I printed it out a few times adjusting the size until I got the correct dimensions of a template, made the job easier.
