you're kidding right?So it was a 15 and now its a 30!
Its was fuse. One that i didnt check bc it was being an ass to get out...well i finally got it out and it was that. So it was a 15 and now its a 30!
X2if you are being serious, it's because the fuses are rated to blow before they overheat the wiring they are connected to. by installing a 30 amp fuse in a slot rated for a 15 amp fuse, you could potentially draw more current through the wiring than it is rated for, which could overheat it, melting the insulation, and possibly causing an electrical short, which could then cause your jeep to catch on fire.
