Kal-El
Are you upgrading to a different EVIC or is this a totally new install?
As long as you have the premium BCM I'm thinking it will fly. You will need that temp sensor, probably some TPM sensors, and preferably as much of the wiring harness as you can get from another KJ so you'll have the proper connectors.
Let us know how the install went. Do you have TPMs installed?
I do have tpms but It looks like I need to replace at least 3, they are 10 years old and supposedly dead, but I will update my progress.
So I got a hold of an 03 Grand Cherokee module, that I combined with the one I already had and was able to combine everything so I have the main module, dome lights that work, and parts of the wiring. As you can see, I fabricated wire harnesses with male/female connectors ( I work with copiers, I have access to a lot of junk wiring). I had already spliced the dome light connector, I use tap splicers with them and with the wires of the diagnostics plug under the dash. It's easy when you can solder, use heat shrink, and diagram your wires colors.
I plugged my unit in, and it worked perfectly, except the temperature. My 06 already had one installed, but I had bought one, and installed the new one. Still no temp. Also no tire pressure, my units don't work supposedly.
So I now am trying to dig up an 05 or newer unit, I have feelers out with the local yards.
BUT, success with the wiring and harnesses.
I have left-over -07 Liberty module.
Jari
Seems to me like it would work. I would definitely not go any older than 05.Would an 07 module be worth it if I have an 05?
I think I'd have to go to a junkyard to get one because they're $70-$90 on eBay (with sunroof controls, which I don't have) so no need to pay that much
Anyone know how much they usually run at junkyards
I've had an 04 EVIC in my 07 for 3 years now, and I'm getting tired of being nagged about the lack of TPM sensors every time I start up.:emotions122:
So I'm curious if anyone has figured out part numbers.
I'm looking for one that has home link, but not TPM...
I currently have P/N: 56010438AD.
I've narrowed it down to knowing I need P/N: 56010520xx. There's AE, AD, AA, & AB.
Does anyone know of which one of those has home link, but doesn't have TMP? :shrug:
Also might add that I live in rural Alaska, so going to a junk yard isn't an option. sad2.gif
