HOW TO: Install an EVIC or OTIS (overhead computer)
Mytmouse
Long Island, New York
Ok, I think I'm ok - ok not great, but ok.
Looking closer at the Ebay EVIC pictures I see the connectors for the lights AND the EVIC with small stubs of wire out of each. Maybe just enough for me to solder 4 wire trailer wiring to.
And according to the "Installing an OTIS" how to web page it's the latest EVIC #56042756AJ
Mytmouse
Dag nab it - so the console retainer bracket p/n 5072348AA I order online, came back as cancelled order due to discontinued part.
So I guess my search for another console retainer bracket p/n 5072348AA is back on.
Mytmouse
Please Help identify correct part
Ok, I went to my local auto wreckers and they came back with this (see below link for pictures).....
I'm not 100% sure - they said it came out of a Cherokee.
Is this what the retainer bracket is supposed to look like ? The numbers on it don't look like the p/n number I got from the threads here...
Please advise?
https://photos.app.goo.gl/5pxbjDhWszisXY1G8
Mytmouse
If that is the correct retainer bracket (I'll know for sure when my EVIC from EBAY arrives, I suppose) how has the 3m tape method work out in the long run through hot & cold temps for you guys?
If not someone suggested to me to use E6000 glue.....
Chungungo
Chile
Hello
If anyone is interested I posted this thread EVIC dont show ambient temperature, only dashes "_ _" , to concentrate all the info in just one single and short post to try to get the Instant MPG along with TPMS and Homelink of course, in a 2004 Jeep Liberty and probably later years.
Any help is appreciate it !!
Mytmouse
Can anyone HELP!
​Ok I thought I had everything figured out and got all my necessary parts. I finally had some time to do this mod. First thing stopped me in my tracks - that is that the dome courtesy light plug / wiring is totally different in my 05 Liberty than the EVIC (56042756AJ) I got from Ebay. I'm going cross eyed from all of the 40+ pages from the HOW TO: Install an EVIC thread - I can't find the wiring difference and /or solution to this. Can anyone HELP!
see link for pictures dome courtesy light plug / wiring differences
https://photos.app.goo.gl/iPu1Z4SYpL8RpCTD6
Mytmouse
I figured out/found the courtesy dome light plug wiring and lights working backwards dilemma from post #96 & #97. Now I just have to figure out how to change/move the wiring within the plug.
As I mentioned last night I hook up the EVIC and powered it up briefly. I did not cut the head linener/mount it yet - the no turning back portion, until I was sure everything is working. All seems to be working except the Temperature reads --F .
The EVIC I got is from a 2004 GC, which reading here, multiple times, says an 04 or newer EVIC will work for my 05 Liberty temp reading to work. I do have a temp sensor installed, even purchased an additional new one, same result. Some say it might just need to register different temps for more than 5 min. I have the Liberty still in my garage as I'm working on other things, so I haven't kept it on longer than 5 min.
I have a few other issues like only one tire is not reading pressure, but the other three show 33,33,32 , I didn't even think I had TPMS sensors in ths tires?..?..?. Also only the front drivers and front passengers door register open/closed, not the any of the rear doors or glass/gate, but still does show on the dash.
See pics - I used tap a fuse on #13 fuse position, and the OBD adapter worked out nice , hope the cutting of the headliner comes out as well..
https://photos.app.goo.gl/URTiTA7KL2sDZ93C6
-TC
_______
[_] [___]
l-----{o||||o}
()_) ()_)-o-)_)
"Yesterday is history, tomorrow is a mystery, but today is a gift. That is why it is called the present." -Master Oogway (KungFu Panda)
Mytmouse
I now had the Liberty out in the driveway running longer than 5 min. STILL NO TEMP. reading.
Does this mean I NEED AN EVIC FROM AN 05 OR HIGHER.... ?
Chungungo
Chile
I have read somewhere in this post that must be a 2004+ Liberty to work the temperature reading, but can not be from a GC.
No Idea if it is true or not.
I still need to figure out the "_ _ " temp thing but no one has replied to my post yet, I guess these jeeps are too old.
Mytmouse
Thanx, yes I believe that is both our problems. So we need an EVIC out of an 04, or 05 to 07 LIBERTY specifically?
I have an Ebay seller who has a few andrelized that, and is asking the part number - he recalls the Liberty's EVIC having a bit different part number from a previous transaction. ..
Does anyone know what the part number(s) would be for an 04, 05, 06 ,or 06 for an EVIC specifically from a Liberty?
Chungungo
Chile
Make it easier, ask the seller what part numbers he has and then search them in Ebay, it will show probably.
Chungungo
Chile
And if dont mind please share them, I have a few, that I also read many pages ago.
Ebay shows them as for Liberties
Mytmouse
The Ebay ads may show "FOR " Liberty's, but that doesn't mean it came out of a Liberty! That's what I'm finding out.
Now to add to my EVIC issues - besides the -- F for the temp. I now noticed all of a sudden when the kids get in the back (open both rear doors) only the right rear started showing open and never clears (shows closed) when the doors are closed. I have to unplug the EVIC to get it to stop showing - only until my daughter opens the right rear door again.
I'm leaving this EVIC DISCONNECTED and going back to just the map courtesy lights until I find the PROPER EVIC ....
Mytmouse
Ebay seller mentioned this;
The last numbers 57aj or 49aj the 56 is tps but I know the liberty has the first half of the number is different..
Any help/ idea of the Liberty part number?
Mytmouse
Got another EVIC (from 05 Liberty) wires different coloring
I just found another EVIC at a wreckers out East of me - they say it's from an 05 Liberty part number P/N 56010520AD...
I see that the wire colors for the EVIC plug are different and the Courtesy Dome light plug is the same as in my 05 Liberty, which is a plus (I wont have to mess with that wiring)...
Now I'm wondering if the way I wired my wiring from the Jeep Grand Cherokee WJ - Overhead console and EVIC and Installing an OTIS How To install an EVIC is going to work?
The say :
EVIC pin #5 Blue / White to fused ignition switch Output (#13 fuse block)
EVIC pin #4 Black/Orange to pin #4 of the OBD port > GROUND
EVIC pin#3 Pink to pin #16 of the OBD port > FUSED B (+)
EVIC pin#2 Yellow/Violet to pin #2 of the OBD port > PCI BUS
Where as this (05 Liberty) EVCI plug has:
EVIC pin#5 Pink / Green
EVIC pin# 4 Black/White
EVIC pin# 3 Red
EVIC pin# 2 White Violet
See Pictures:
https://photos.app.goo.gl/9itUksTtsjE9Bzck7
Mytmouse
IF the pins/functions to the EVIC are all be the same ( ? )
If so then the color code of the wiring does NOT matter as long as the pins/function at the EVIC are the SAME....???....????
Can anyone Confirm this for me ?
Mytmouse
Wait am I reading this correctly - that if this is an 05 EVIC to get the TPMS to work, it is not just a matter of getting 4 (or 5) tpms sensors and a Retraining magnet ?
That the 05 that came with TPMS as an option has a different set up - external antenna's in each wheel well?
Kal-El
Glendale, Arizona
It's been a while since I've messed with EVICS....but if I recall correctly....if your EVIC has the TPMS option, not installing the wheel sensors will result in a very annoying chime and a display that constantly reminds you of a "bad or missing sensor".
