Need help selling a NSG370
Ascho7
hey all, I’m a TJ owner that got scammed into buying a brand new from factory NSG370 they listed for a TJ, but it is a 2WD version and am having no luck selling it. Looks like you have to be a member to post on the marketplace here, and was hoping someone can help me out either to post it or put me in the right direction. I currently have it posted on EBay and fb marketplace but am having no luck finding a buyer. Thank you!
Can't you swap the tail housing or use it with a separate transfer box?
I doubt many people on here will want a 2wd box, the NSG was only used on the export manual 2.8CRDs as far as I know and then in 4x4 arrangement.
It's normally found in Mercedes cars, you might have luck on a Mercedes forum or a hotrod forum, it's a strong box and would be nice behind a powerful engine.
JMichael2006
I found the rear housing for it on E-Bay for $260. You could just rebuild it as a 4x4 unit.
JMichael2006
Unbolt the output flange in the tail housing, I believe you'll find the setup for 4x4.
u2slow
BC
Is it the TJ or KJ bellhousing pattern?
Our 4wd KJ (3.7L) has the NSG370.
Ascho7
What's the bellhousing pattern?
KJ bellhousing. Unfortunately that would mean using the TJ front and back case halves and putting everything back together and then I have a worthless tj internal and kj case. Unless you’re asking because you’re interested
u2slow
BC
I bought my own spare trans. Anyone that has one of these should have a spare.
The guts are worth plenty. Price the shifter tower, and the selector/fork/rail assembly.
