O2 sensor wiring?
jmarks99
Saint John,Washington State
working on a 03 sport 4wd with 3.7 v6 and auto ******. Need to replace O2 sensor bank2 sensor2. However, the sensor is broke off and the O2 harness is nowhere in sight. How is this harness routed?
Damotee
Cape York, Australia
I had the same problem. The harness was unreachable so I had to cut the wires and splice on the new sensor. I'm going to re-do mine because I'm not happy with my splice job. Use a good connector, don't just twist the wires together and wrap them in electrical tape like I did :)
Even better if you could solder the wires together.
jmarks99
That's fine but how is it originally routed? Can't find the harness at all!
Leeann
Maryland
Harness routes from the engine compartment across the top of the transmission.
