jmarks99
working on a 03 sport 4wd with 3.7 v6 and auto ******. Need to replace O2 sensor bank2 sensor2. However, the sensor is broke off and the O2 harness is nowhere in sight. How is this harness routed?
I had the same problem. The harness was unreachable so I had to cut the wires and splice on the new sensor. I'm going to re-do mine because I'm not happy with my splice job. Use a good connector, don't just twist the wires together and wrap them in electrical tape like I did
Even better if you could solder the wires together.
Harness routes from the engine compartment across the top of the transmission.
thanks I should be able to find it now.
