Backspace to Offset Conversion Chart
The table below is a quick reference for finding offset- pick the rim width and follow the row over to the backspace of your wheel.
Bolt pattern or lug pattern or bolt circle is determined by the number of bolt holes and the bolt circle diameter.
Hub Diameter or center bore is the hole at the center of the wheel.
Rear spacing or back spacing is the distance from the backside of the wheel mounting pad to the outside of the rim flange.
Offset: The distance from the centerline of the wheel to the mounting surface of the wheel.
Negative offset: When the back of the bolt pad is closer to the inside of the wheel; when mounting surface is inboard of the rim centerline.
Positive offset: When the back of the bolt pad is closer to the street side of the wheel; when the mounting surface is outboard of the rim centerline.
Bead-Loc A device which captures the tire bead between it's flanges, usually secured by bolts to keep tire bead from dismounting. Usually used in dirt circle track or off road applications where low tire pressures are used and hitting ruts or other vehicles are common. Left: An example of a Bead-Loc wheel
Info on Stock Wheels:
Bolt Pattern: 5x4.5" or 5-114mm
Backspace: 5.5" (might be a hair larger than this actually)
Offset is 41mm ( I know the chart says 38, but I found 41 from a tire vendor that said the factory wheels are 41 )
Wheel size is 16 x 7
Stock Tire Size ranges, but 235/70R16 is most common.
If anything seems wrong please correct me.
Bennett
