If I added 3 clevis nuts on each side, would you recommend getting a set of rear iso to level it ?
Yes if you add 3/8 inch clevis in front it will be higher , so add one per side upper iso to level it out. This will put you at 22.0-22.25 when settled in
Why not add plates and Clevis ring to front for extra 1/2"?
Sent from my iPad using Tapatalk
Clevis and top plates would add more than 1/2 inch just for clarification
3/8 inch clevis adds 3/4 inch
1/4 inch top plate adds 1/2 inch
both together add 1.25 inches
Got it
I couldn't figure out before how many clevis it would take to get to 3/4 but now I know
I don't want to add the top plate and 3/4 clevis just because I don't want to worry about cv's and such right now
Thanks for the info
never understood why clevises and plates add X2 of their height to the lift, can you explain?
also another Q - for going with the OP Bilstein configuration - does one need to also buy a bushing kit for those shocks?
Picture where the clevis attaches to the lower control arm - it isn't at the end of the LCA at the lower ball joint. If it attached there then there would be a 1-to-1 ratio; for example, if you added a 1/4" top plate you would get 1/4" of lift.
But since the clevis attaches to the LCA at approximately the midpoint (halfway between the ball joint on the outside and the cam bolts on the inside) there is a doubling affect because the clevis is acting upon a lever. Here's a way you can see it in action:
Find a 12" ruler and set it on it's edge. Grab the end of it and lift it one inch off the table. The edge will be, well, one inch off the table (I'm not be a smart aleck - there is a point here!)
Now grab the ruler at the 6 inch mark and lift that portion under your fingers one inch off the table and look at the lifted end of the ruler. The end is TWO inches off the table even though you only lifted your portion up one inch - that's the lever effect and it's the same way the clevis acts upon the LCA. And explains why a 1/4" top plate gives you 1/2" of lift.
Here's a visual that somewhat explains the lever effect (this explains it from the standpoint of the lever's ability to do work.) But picture the fulcrum as the clevis with one end of the lever attached to a fixed point (the cam bolts on your KJ) and you can see how a small movement on one end generates much larger movement on the other:
Does that help?
Thank you Bob! That's eye opening.
So much knowledge here it blows my mind.
I think I have a misunderstanding on where the clevis ring goes. I thought it is positioned on the top of the coilover assembly just above the spring below the top "ceiling" of the shock - the cam bolts.
no hockey pucks?
You will also need new front upper shock mounts as well.
