Rattle under jeep
ckorch
Arkansas
Anyone with jba y link have this problem. I have a random rattle that comes and goes and this seems like a candidate for the rattle
Sent from my SPH-L720 using Tapatalk 2
That's the source for sure.
Just remove the sway bar - you don't need it anyway. I removed mine a long time ago and no problems. You can also take off the "bull nuts" hanging from the differential if you want to remove more unsprung weight.
ckorch
Arkansas
Wierd question but what are the negative affects of removing the sway bar? I tow a popup camper so not sure it would matter.
4x4kayak2112
tx
Rear sway bar removal....I can't tell, very happy.
Front sway bar removal = death
Sent from my Home Phone using Tapatalk
ckorch
Arkansas
does it affect stability while towing? my popup is like 3k lbs. right now i can tug it 65-70 with no issues with sway.
1BADKJ
Barnegat NJ
Does it sway left and right or teeter totter. sway bar only helps with teeter totter not left to right movement...Yank it out...
4x4kayak2112
tx
Nope had my rear off for over 100k. Even with towing a 3500 28ft rv I can't tell a difference
I tow a 2400lb boat/trailer and have been to Tennessee from Ohio several times driving down I-75 at 75+ MPH and never a problem with sway.
Problems with other idiot drivers? Yea, but that's a different topic... :biggun:
Hedsic
Des Moines, Iowa
Hmmmm! This might explain the sound I've been hearingl. It's pretty faint, I can only hear it when I am next to a curb driving or something out that allows the sound to bounce off. Almost a chain rattling sound while driving. Really faint though not loud at all.
greene
Texas
I got some 1.5” X 1/8” thick steel strap that I am going to use as spacers under the rear sway bar bolts. Because I am having the same problem.
I tow a 5X8 open and a 6X10 enclosed with mine and no problems with the sway bar being off
