- Joined
- Dec 17, 2006
- Messages
- 10,612
- Reaction score
- 42
YesI'm in upper Michigan where it gets pretty cold in the winter. Is 80w90 Dino gear lube OK to use in both diffs????
Your engine was designed for 5w-30,you will be fine.This is my first time postingI accidentally stuck 5w30 in my engine today and it says it takes 5w20 its an 07 liberty and I used the z max in the oil will this damage my engine
Liberty's come factory with ATF+4.You can replace Mopar PS with ATF+4 only if you professionaly flush the PS system. You shouldn't mix up those fluids.
Cheers!
Liberty's come factory with ATF+4.You must be registered for see images attach
Sent from my SM-G900V using Tapatalk
Well then if not all may i ask what years didn't use the atf+4. Because I can't find anything that says otherwise. I'd like to know so I don't give bad info anymore.Not all.
Thanks for your recommended fluids! With all the Jeep Liberty horror stories filling up the internet concerning carbon buildup and valve problems, do you recommend using "Plus" or "Premium" to that of "Regular" gas? And is there any truth into those horror stories? Thanks!!!
In Australia, our fuel comes in 91 octane, 95 octane and 98 octane. I use the 98 octane. It's more expensive but it gives much better fuel economy and more power.
